The 140 Meter White Pearl
  • The 140 Meter White Pearl
    Composites specialists Magma Structures (Portsmouth, Hampshire, UK) reported on June 14 that it has delivered three of what it says are the world’s tallest carbon fiber composite free-standing masts. The rigs are designed to withstand bending loads of more than 40 Mn — more than twice the load on a Boeing 787 Dreamliner wing. The masts were ordered by a German shipyard and are destined for a sailing superyacht.
    Built at Magma Structures’ waterside manufacturing facility near Portsmouth, the masts have taken more than three years to develop, test, design and build using advanced composite manufacturing processes. More than 70 people have worked on the build of the rigs, including an in-house team of specialist composite design engineers.
    The rig concept was designed by Dykstra Naval Architects in The Netherlands; the load analysis and engineering drawings were compiled by Magma Structure’s in-house engineering design team. Each mast is able to rotate using systems mounted on "wings" at the side of each mast, adding to both the design complexity and build challenge.
    Magma says a high-performance carbon fiber was used in the manufacturing process of the masts. Despite their height, each cantilevered freestanding mast weighs around 50 tonnes. The masts support a sail area greater than a standard sized football/soccer pitch, with full automation in terms of sail deployment, setting and reefing.
    Magma also says the free-standing, rotating rigs are intrinsically safer and more reliable than conventional rigs where failure through fatigue or overload of the many rigging elements can occur. The absence of standing rigging results in a much cleaner and uncluttered deck as well as significantly reduced maintenance issues.
    The rigs are embedded with fiber optic sensors to give real-time, comprehensive load data on all aspects of the rig as well as safety warnings, historical data, condition monitoring and information to optimise the sailing performance.
    Magma Structures undertook all the structural engineering design, prototyping, testing, and build of these highly technical rigs and is responsible for commissioning the rigs, controls, sails, automation and monitoring systems.
    Clive Johnson, managing director of Magma Structures, says, “These rigs are amongst the most technically challenging free-standing carbon composite structures to have been manufactured due to their size, design load requirements and the marine environment in which they will be used. The skills developed and experience gained from building these rigs are already having a direct impact on projects we are developing in other sectors including bridges, stadia and buildings where the benefits of manufacturing in composites can be significant.”
    Damon Roberts, technical advisor to the project, says, “The high strength, fatigue resistant nature of carbon has been the key in enabling us to develop and manufacture a free-standing structure much larger than anything currently built, including the current generation of wind turbine blades, and with much higher bending loads. The embedded fibre optic monitoring data is invaluable in giving us real-time data to optimize the sailing performance as well as verify the design concepts and give us load case data to minimize the maintenance.”
    http://www.compositesworld.com/news/...peryacht-masts
    http://www.yachtemoceans.com/magma-s...-90m-dyna-rig/
