The LA 28 was drawn by Martin Menzner of Berckemeyer Yacht Design and is offered by the LA yacht and ship building GmbH as a series in different design variants and built. Yacht Nr. 1 is under construction. Currently has begun on the interior. These boats will be optionally build with fixed keel, lifting keel or canting keel. The mounting machine can optionally be designed as a diesel engine or electric motor. The ship will be handed fit, has a wet room with toilet and can be carried out if necessary, with 4 beds. Despite handed suitability of this ship will be able to ride even at regattas forward.
Specifications of LA 28
Length 8.50 m
Width 2.50 m
Draught 1.75 m
Weight 1.5 t
Mainsail: 22,0 m²
Jib: 15.0 m²
Code 0: 40 m²
Gennaker: 75 m²
Hull cold molded
Rowing rowing single or double
Ballast carbon fin with lead
Mast Selden Carbon
Rigging Rod
Rolling device Harken under deck
Harken winches - Radial
Deck Harken
Jefa steering
Motor optional 2.5kW electric outboard
Carbon bowsprit, foldable
Battery opt 180 Ah
Water opt. 50 l
Shipbuilder LA yacht and boatbuilding GmbH
Design Martin Menzner Berckemeyer Yacht Desi
http://www.la-yacht.de/segelyachten/segelyacht-la-28/
